Rear VZ sedan suspension bush's
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by jas98, Apr 24, 2013.
  1. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    Hi, me mate has a VZ sedan, and has just brought a suspension bush kit (not including the rear crossmeber mounts as there already new)
    anyway, i know how to do the front, done the fronts a few times, however how do i remove the rear bushs? its the ones for the toe etc? i think
    are they a matter of just pressed in rubber or is there a steel tube?
    and another thing............it looks soooo much simpler then a BA onwards ford falcon rear end haha
  2. MYVESSV8
    MYVESSV8 Well-Known Member
    Brisbane/GoldCoast
    VE 6LT M6
    what make kit, do you have pics so people can advise you,
  3. jas98
    jas98 Active Member
    maryborough QLD
    sorry, its nolthane so it would be a push in by hand, but im trying to find out if the original bush's are the same or have a metal sleave?
  4. Clutchy
    Clutchy New Member
    Wild west of Melb
    vz wagon
    They have a metal sleeve well all the ones I've done or seen done have had.
  5. MYVESSV8
    Brisbane/GoldCoast
    VE 6LT M6
    agree with clutchy, most have sleeves on what I've done as well, will need a tool to remove (I think someone made their own on this site)
  6. Benboy
    Benboy Well-Known Member
    Hill River, SA
    2007 SVZ Wagon
    It's pretty simple to make your own bush remover. Bolt to go through hole in bush (put a washer on first so that it cannot get through the hole), push through hole, put a large washer on so that it is larger than the suspension component holding the bush, screw nut on and keep turning nut until bush is removed. You will have to make sure that the bolt has enough thread to facilitate this form of removal.
  7. MYVESSV8
    Brisbane/GoldCoast
    VE 6LT M6
    pics of homemade tool
  8. morphix
    morphix Member
    Cardiff, NSW
    2004 VZ SV6 5-Speed Auto
    Would be good to see this tool lol, i'm thinking about replacing my stuffed bushes too.
  9. mr calais 5.0
    mr calais 5.0 New Member
    victoria
    vy s 2003
    A large socket over the bush with a bolt through it then a washer and nut at the other end.. Just wind the nut in and it will pull the bush out.. Do the same to reinstall the new, don't forget to lube it to make it slide in easier..
