_R_J_K_
- Dec 20, 2008
- 6,723
- 1,856
- 113
- Zenki S14
I don’t have the results for my last wheel alignment, they were “not available” from the workshop that did it.
Like VC said, the rear end is largely un-adjustable unless you get a camber kit installed. You will have toe adjustment (VX2 onwards do), which will in some way affect camber, but not in the way you think because of how rudimentary the swing arm suspension is in Commodores. The camber flaw is well documented with IRS Commodores, it was at its worst in the series 1 VT.
Having said that, -1.5 degrees of camber isn't bad (and it's by no means extreme), but you probably don't want to go a huge amount past that point. Honestly is probably a good point for handling.
Just monitor your tyre wear until you have a better idea, no point fixing a problem that might not exist.
front end, kind of like a flat disc with holes goes behind the wheel to make them sit out further.
Lol. Dunno what they were trying to achieve by changing wheel offset, doesn't change alignment at all.
