rear window not going all the way up
PlenumBiscuit
VY Commodore
as title says rear window not going all the way up
passenger side
see pic
guessing i gotta take the door card off and get inside the door?
mpower
push it manually as you get someone to hold the button.
it will at least go up until you get time to look at it - but usually a bit of graphite in the tracks and a few up and downs will free it up.
oska
vx custom 600RR
There is an adjustable stop on the vertical part on the window frame it's about 2" down from the top on the B pillar side
it's a 3 mm hex bolt, just loosen it don't take it all the way out
