Reasons the TCC won't engage
savage1987
Donating Member
www.facebook.com
Torque converter won't lock up. I'm a bit over poking and prodding things on the car, just done a motor swap. Anyone able to point me in the right direction to find the plug I have surely left out?
Sam
levymetal
TURN MY HEADPHONES UP
Somerville, Victoria
levymetal.net
HSV ENHANCED VP CALAIS
what's the temperature like when it's running? coolant temp sensor might not be working correctly. the torque converter only locks up when the coolant temp sensor is reading above some certain temp, and if it's reading too cold, it won't lock up.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
yip coolant sensor needs to read right .tps sensor volts need to be at a certian amount ,speed needs to be above 80+km/h.kickdown adjusted.fuses all good.temp switch on trans plugged in
camstatic
I'm back babeh.
Regional SA
VZ SS
Mine wasn't engaging for a while, after poking around for a decent amount of hours on it, it turned out the clutch itself was stuffed and it was just slipping when it was engaged anyway.
wildss
42
s.e melb
vnss
didnt greenfoam start a thread a lil while ago about the sam eproblem?
turned out his ecu was the culprit
camstatic
I'm back babeh.
Regional SA
VZ SS
Really need to log it and see if it's trying to engage.
savage1987
Donating Member
www.facebook.com
will check that trans temp switch... where do I look, on the trans itself?
Unlikely, the TC is only young, new one with rebuilt auto about a yr ago, worked fine with old motor
didnt greenfoam start a thread a lil while ago about the sam eproblem? turned out his ecu was the culprit
My ECU is the same one that was running fine on the old motor.. locked up every time at 90kph
Checking the fault codes do the trick?
greenfoam
101
VP Executive R-spec
Coolant sensor / tps / ecu
take your pick :)
Chirpstr
A new project attack
34
VR Berlina M5, VP M5
Check your battery/reg because if the computer is not getting enough power then this can also cause this.
