rebuild parts ofr turbo what do u suggest?
Goon
Scientific Tuning
BrisVegas. QLD
VY CUSTOM.
Any suggestions on what parts i should rebuild to my engine to have my turbo running sweet..??
i dont wanna run anymore then 16psi... its just for the rb30 motor.
I have till the end of july, but i dont wanna have to take the motor even though i have a crane, but what a biatch that is to do..
Goon.
ps. i want cheap part ideas.
Goon
Scientific Tuning
BrisVegas. QLD
VY CUSTOM.
It's just a stage 1 turbo btw, i just want a parts list that would be enough to handle the turbo.
ps. should i rebuild the auto gearbox? im not intrested in a 5 speed.
leigh 7005
adelaide
vb sle
how much are you spending? piston,rings,get crank machined block bored new rods thats the main things get a balance,cam,heads ported mains and conrod bearings.
Goon
Scientific Tuning
BrisVegas. QLD
VY CUSTOM.
Do u think 1-2g's is enough ? thats 4 the engine :whistling
VL Berlina 5speed
Apprentice Panel Pusher
35
Project VL Show car, VS Exec, VY Ute, YZ250F
easyist way to work it out is sent a power goal and how you want to achive it
then look into what combos you can use to achive it and what you need to do it then go look into pricing
if your just after a good reliable bottom end which will be safe just get everything rebuilt and balanced properly
possibly change the rods as i beleive they are weakness and your set
just make sure your tune perfect to suit your set up
Goon
Scientific Tuning
BrisVegas. QLD
VY CUSTOM.
On the reliable part, does that include the pistions also? forged is all i can find..
cracker
16psi... just use a standard n/a motor no reason why it wont last, allong as the tune is good and u keep 98 in it
Pub247
Melbourne S.E.
Ford Fairmont
Rb30 rods are good for 300kw according to some people im sure a balanced bottom end will help cope with that. Forgies cost around 1300 unless your in the know so with those theres not much chance to build a decent motor for under 2000. For a good rebuild budget $5000
nasty1
adelaide
vy2 clubsport
cheap part idea usualy means cheap qaulity lol.save your doas and build something with qaulity
Goon
Scientific Tuning
BrisVegas. QLD
VY CUSTOM.
Thanks guys, im gonna run with the turbo for awhile at 6psi just to be safe.. if it go's ill rebuild.. I'm still gonna save until i get close to having enough for a decent motor or possible just buy the parts over time for the longrun...
THanks for the help!
