Pub247
- Apr 14, 2006
- 3,372
- 59
- 48
- Location
- Melbourne S.E.
- Ford Fairmont
if you dont already know you can spin the housings by undoing the the nuts and flanges that hold them to the center.
As said the oil return are gravity feed having them at top will cause a build in oil and pressure which will lead to the seals failing.
As said shorten the fuel line between the 2 rails to remone the bow in it if you have one have it going downwards instead. Also when you redo the drains remove the 90 fittings from and have them as straight as possible.
JUst helping you here is there a reason why the fuel reg is on passenger side?
Also Speedpro in dandenong is one of if not the best performance parts joint in melbourne their prices are very good worth checking them out not sure where you live though
