rebuilt to suit high boost
17UCK!
vs III commodore ute
i got a gen3 just wonding wat needs 2 be done 2 run twinturbos on decent boost.. just internally.. not stuff like exhaust n ****.. stuff like cam,heads ect.and a estimate on pricing. i do wanta beef up the engine cuz i will like to run the turbos high on the track n ****.
H1GHROLLR
CHEMICALLY SUPERCHARGED
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
i just built a N/A ls1 with all forged pistons and race bearings/rings and it cost around the $15,000 including cam and heads but thats using all real good gear , , but just remember that the ls1 is just about built to survive a nuclear holicaust and there are heaps of people running pretty decent PSI through them and there holding together and people using stupid ammounts of nitrous like 500hp shots
BradSV8
Nitrous Junkie
41
VY SV8
Who is running a 500 hp shot??
It can cost anywhere from 5k and up depending on what parts you use.
Brad
H1GHROLLR
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
there are a few people in australia using close to 500 hp shots ,a white vt thats stock running 500hp shot doing 10.9's and has done about 35+ passes he is over east some were
RED1M8
South Auckland
VX 383 turbo & VK Royale LS1
Stock crank is plenty strong enough, the factory pistons are the weakest link followed by rods.
Just get forged lower compression pistons, a good set of rods with ARP bolts, ARP mains stud kit, ARP head stud kit, factory multilayer head gaskets, dual valve springs, factory heads are ok, and a turbo friendly cam would be optional.
cpbait
vy ss commodore 5.7ltr
yeh iv heard that the gen3's are tough as and iv heard they crumple under moderate power upgrades especialy moderate boost applications
would love to modify my gen3 with a 383 stroker kit, decent cam, mild head work(stage2 i believe they call it) and a top mount wipple super charger and not have to change to what i have been told is stronger in the ls2/ls3 engines, but i thought they were all roughly same strength blocks, just different stokes and bore sizes.
SEPERF
www.seperformance.com.au
VL LSX
The cheapest and safest option:thumbsup:
17UCK!
sick cheers guys! but if im rebuilding do you's recon its best off just gettin a motor with heaps of kms for cheap then just rebuilding it with new stong parts or just going off gettin a more costy engine with low kms.. and rebuild that.. ....
also
how much would this cost with decent parts?.. and i might as well get a cam wile its all open.. i like the lumpy sound of cams
SEPERF
VL LSX
put a ls2 etc with a nice cam into your vs ute and you can drive it every day and dust most turbo vt-ve cars:yeah:
