VL Berlina 5speed
Apprentice Panel Pusher
- Oct 3, 2005
- 2,684
- 30
- 0
- Age
- 35
- Location
- Adelaide
- Project VL Show car, VS Exec, VY Ute, YZ250F
well after finding the info on the recall for the vl series i found the recalls for all the other models, so i thought i may as well post them up for every1 to see
i tryed to get it in model order as best as i could, hopes yous find it helpful.
all this info i found on a goverment site, and there was many other models from holden but i only selected the cars that are based on the commodore. if you what another model checked ask and ill look for you.
Model - HOLDEN Commodore, Calais, Astra (1986)
Problem: SEAT BELT TONGUE FAILURE
Make: HOLDEN
Model: Commodore, Calais, Astra
Variant:
Date Range: 1986
VIN Ranges:
Status: Inactive
Defect: Two batches of Cooldrive seat belt tongues failed ADR dynamic tests.
Consequences: Could fail to perform satisfactorily.
Corrective action: Replace seat belt assembly if from suspect batches.
Notif. Date: 5/11/1986
DOTARS No.: R86/014
Supplier Name: HOLDEN
Campaign No.: 86-H-02
Model - HOLDEN Commodore VL, Calais (1986)
Problem: INSTRUMENT WIRING DAMAGED
Make: HOLDEN
Model: Commodore VL, Calais
Variant: Auto
Date Range: 1986
VIN Ranges:
Status: Inactive
Defect: 6 Cylinder models with automatic transmission only. Instrument wiring located in the centre console can be damaged by the automatic transmission selector mechanism.
Consequences: Fire risk.
Corrective action: Provide positive retention for the instrument lighting wiring harness.
Notif. Date: 10/11/1986
DOTARS No.: R86/015
Campaign No.: 86-H-01
Problem: POWER STEERING ASSEMBLY FAILURE
Make: HOLDEN
Variant:
Date Range: 1986-1987
VIN Ranges: L220743, L242128 J104955, J132000
Status: Inactive
Defect: Power steering assemblies supplied by James N. Kirby may have been produced with incorrect attachement of inner tie rod end housing to the steering rack.
Consequences: Inner tie rod ball joint can become detached from the steering rack, causing a reduction in steering control.
Corrective action: Inspect and replace if defective.
Notif. Date: 23/12/1986
DOTARS No.: R86/016
Campaign No.: 86-H-03
Problem: BRAKE MASTER CYLINDER FAILURE
Make: HOLDEN
Variant:
Date Range: 1987
VIN Ranges: L235800, L255100 J124000, J144000
Status: Inactive
Defect: Incorrect crimping of the joint between the front and back shells of the brake booster. Vehicles with 3.0E (non-turbo) engine are affected.
Consequences: The two shells may come apart. As the brake master cylinder is attached to and supported by the front shell, function of the master cylinder is lost.
Corrective action: Inspect crimping and replace booster if crimping found incorrect.
Notif. Date: 28/08/1987
DOTARS No.: R87/017
Campaign No.: 87-H-02
Problem: STEERING KNUCKLE CRACKS
Make: HOLDEN
Variant:
Date Range: 1987-1988
VIN Ranges: J145736, J153237 L257205, L268578
Status: Inactive
Defect: In-plant investigation revealed quench cracks in steering knuckle forgings received from ANI National Forge.
Consequences: Potential loss of steering control.
Corrective action: Inspect for cracks and, if evident, replace steering knuckle and tube assembly.
Notif. Date: 22/07/1988
DOTARS No.: R88/032
Campaign No.: 88-H-02
Model - HOLDEN VN, VQ
Problem: DETACHMENT OF EXTERIOR SUNSHADE
Make: HOLDEN
Model: VN, VQ
Variant:
Date Range: 1989-1990
VIN Ranges:
Status: Inactive
Defect: Concerns moulded plastic accessory front windshield sunshades sold for VN Commodore/Calais 1988-90 and VQ Statesman/Caprice 1990. Under extreme wind forces the sunshade may fracture and become detached from the vehicle.
Consequences: Detached sunshade may cause injury.
Corrective action: Existing moulded shades are being removed as a precaution, until replacement shades, which are manufactured from GRP (fibreglass), become progressively available.
Notif. Date: 2/07/1990
DOTARS No.: R90/023
Campaign No.: 90-H-01
Model - HOLDEN Commodore VN, Calais, VG Ute (1988-1990)
Problem: REDUCTION OF SEAT BELT STALK STRENGTH
Make: HOLDEN
Model: Commodore VN, Calais, VG Ute
Variant:
Date Range: 1988-1990
VIN Ranges: 6H8VNL35HJL273550, 6H8VNK19HML465000
Status: Inactive
Defect: The inner stalk and buckle assembly of the drivers side seat belt lightly contacts the seat frame.
Consequences: There is a potential for the belt webbing which is contained within a corrugated plastic sleave to become abraded. If this occurs the strength of the seat belt stalk will be reduced.
Corrective action: Replace the seat belt stalk if damaged or re-work it to prevent contact with the seat frame.
Notif. Date: 13/05/1994
DOTARS No.: R94/021
Campaign No.: 94-H-01
Model - HOLDEN Commodore VG, VN, VQ (1991)
Problem: WHEEL STUD FRACTURE
Make: HOLDEN
Model: Commodore VG, VN, VQ
Variant:
Date Range: 1991
VIN Ranges:
Status: Inactive
Defect: Concerns vehicles fitted with steel road wheels. These wheels may have been distorted during tyre fitment leading to incorrect seating of wheel on hub.
Consequences: Wheel studs may fracture in service.
Corrective action: Inspect and replace wheels and studs if necessary.
Notif. Date: 16/05/1991
DOTARS No.: R91/016
Campaign No.: 91-H-02
Problem: BRAKE PIPE DAMAGED
Make: HOLDEN
Variant:
Date Range: 1990-1991
VIN Ranges:
Status: Inactive
Defect: Concerns vehicles fitted with heavy duty brake systems which may have less than minimum specified clearance between the brake pipe and the steering shaft. Brake pipe may be damaged by contact with steering shaft.
Consequences: Loss of rear brake effectiveness.
Corrective action: Inspect and adjust if clearance is insufficient.
DOTARS No.: R91/017
Campaign No.: 91-H-03
Model - HOLDEN Commodore VR, Calais (1993)
Problem: INADEQ. CRUISE CONTROL CABLE RETENTION
Make: HOLDEN
Model: Commodore VR, Calais
Variant:
Date Range: 1993
VIN Ranges: L645551, L682301
Status: Inactive
Defect: The cruise control cable retention to the throttle body bracket is considered to be inadequate.
Consequences: The cruise control outer cable locking mechanism may become detached from the throttle body bracket preventing the throttle from closing fully resulting in unintended acceleration.
Corrective action: Fit new revised cruise control cable support bracket and install a tie strap to the cable retaining legs.
Notif. Date: 7/12/1993
DOTARS No.: R93/033
Campaign No.: 93-H-02
Model - HOLDEN VR Executive, VR Berlina, Acclaim
Problem: FAULTY THIRD SEAT HOLD DOWN BRACKETS
Make: HOLDEN
Model: VR Executive, VR Berlina, Acclaim
Variant: Executive (Series II), Berlina/Acclaim (Wagon)
Date Range:
VIN Ranges:
Status: Inactive
Defect: When the third seat is fitted to vehicles the operator may have difficulty locking the seat fully down into position.
Consequences: This could cause injury to passengers in case of an accident.
Corrective action: Replace the third seat hold down brackets. Parts disposal to be advised.
Notif. Date: 10/07/1995
DOTARS No.: R95/042
Campaign No.: 95-H-05
Model - HOLDEN VR, VS (Up to October 1996)
Problem: TRANSMISSION FLUID OVERHEATING AND IGNITING
Make: HOLDEN
Model: VR, VS
Variant: Automatic, Towbar
Date Range: Up to October 1996
VIN Ranges: L645621-L979936 for V6 engined vehicles. L645621-L986809 for V8 engined vehicles.
Status: Inactive
Defect: Overheating of the automatic transmission fluid can occur during towing.
Consequences: Overheated fluid can discharge from the breather tube or dipstick tube and may ignite if it contacts hot engine components.
Corrective action: Replace dipstick with one that has a lock-seal top and reroute the transmission breather hose.
Notif. Date: 22/11/1996
DOTARS No.: R96/083
Campaign No.: 96-H-03
Problem: Headlamp patch harness connector corrosion
Make: HOLDEN
Model: VR, VS
Variant:
Date Range: 1993-1997
VIN Ranges: Statesman VR, VS and VR Series II: 6H8VRY19URL674058-6H8VSY19HVL213857; Caprice VR and VS: 6H8VRZ19URL676992-6H8VSZ19HTL939663.
Status: Inactive
Defect: Right hand side headlamp patch harness connector; due to insufficient clearance to the battery, contamination caused by battery vapour emissions and/or water corrodes connector.
Consequences: Short circuit and fire.
Corrective action: Examine headlamp patch harness connector for heat damage or corrosion on either the connector body or terminals. If wiring insulation heat damaged replace patch harness assembly. If any connector or terminal damaged replace all terminals and both connector halves. Relocate patch harness connector away from the battery.
Notif. Date: 15/10/1998
DOTARS No.: R98/063
Campaign No.: 98-H-03
Model - HOLDEN VS (1997)
Problem: Steering gears - hardened rack bar
Make: HOLDEN
Model: VS
Variant: Series II
Date Range: 1997
VIN Ranges: (no VINs specified)
Status: Closed
Defect: Steering gears assembled with incorrectly hardened bar
Consequences: Incorrectly hardened bar may fracture in service resulting in reduction of steering control
Corrective action: Remove and replace steering rack with a manufacturing code 24/6 on the rack bar.
Notif. Date: 24/07/1997
DOTARS No.: R97/033
Campaign No.: 97-H-01
Problem: Retaining clips foul inlet fuel hose
Make: HOLDEN
Model: VS
Variant: Series II - V8 Police Vehicle
Date Range: 1997
VIN Ranges: Production Serial Numbers: L210869, L218779 to L253126.
Status: Closed
Defect: VS Series II police vehicles fitted with a V8 engine have an Auxiliary Power Supply Harness routed along the plenum chamber wall, rear of the engine bay, positioned by three (3) retaining clips. One of these retaining clips may foul and damage the inlet fuel hose.
Consequences: Damaged fuel hose has risk of fire in engine bay.
Corrective action: Remove existing retaining clips and replace with new revised retaining clips.
Notif. Date: 15/08/1997
DOTARS No.: R97/041
Campaign No.: 97-H-02
Model - HOLDEN VT (1997)
Problem: FRONT BRAKE HOSE BECOMES DISLODGED.
Make: HOLDEN
Model: VT
Variant:
Date Range: 1997
VIN Ranges: 6H8VTX69PWL262756-6H8VTX69PWL282732.
Status: Closed
Defect: Depending on which of two types of front brake fitted, the brake hose may become dislodged. Due to incorrect alignment of the grommet on the suspension strut the hose may become unrestrained with possible contact between the hose and the tyre.
Consequences: Damage to the brake hose may result in loss of front service brakes.
Corrective action: Inspection of vehicle to determine which hoses fitted and replace any nonconforming hose.
Notif. Date: 17/02/1998
DOTARS No.: R98/006
Supplier Name: Holden Special Vehic
Campaign No.: 98VT05F001
Problem: BRAKE PEDAL ASSEMBLY WELD FAILURE
Make: HOLDEN
Model: VT
Variant:
Date Range: 1998
VIN Ranges: L287611 to L321633.
Status: Inactive
Defect: Batch of brake pedal assembies may have suspect welds.
Consequences: Failure of brake pedal assembly may cause loss of vehicle control.
Corrective action: Test strength of brake pedal with special tools provided. If the weld strength is not to specification, the brake pad will seperate during the test. Defective pedals to be replaced.
Notif. Date: 18/05/1998
DOTARS No.: R98/024
Campaign No.: 98-H-02
Problem: Unprotected wiring to seat lifter motors
Make: HOLDEN
Model: VT
Variant:
Date Range: 1997
VIN Ranges: 6H8VTK69HVL246596-L259927.
Status: Inactive
Defect: Seats assembled without a PVC sleeve to protect the wiring harness to the seat lifter motor. Unprotected wiring routed between the motor bracket and the mat supporting the seat cushion is damaged with use, exposing wiring and resulting in a short circuit.
Consequences: Fire.
Corrective action: Inspect wiring harness to seat lifter motors for the presence of the PVC sleeve. If not installed, replace wiring harness. [The new harness includes the PVC sleeve].
Notif. Date: 3/03/1999
DOTARS No.: R99/036
Campaign No.: 99-H-02
Problem: Faulty airbag Sensing & Diagnostic Module [SDM]
Make: HOLDEN
Model: VT
Variant:
Date Range: 1998
VIN Ranges: Tag No L367025 to L413138
Status: Inactive
Defect: Certain batches of Sensing & Diagnostic Modules [SDM] were manufactured with a faulty microprocessor. These modules sense inaccurate information and impede the behaviour of the Supplemental Restraint System [airbag and seatbelt pre-tensioners].
Consequences: Reduced effectiveness of the Supplemental Restrain System to protect vehicle occupants.
Corrective action: First check the SDM serial number. Then, if SDM serial number within the affected batches, replace SDM.
Notif. Date: 23/04/1999
DOTARS No.: R99/062
Campaign No.: 99-H-04
Problem: Casting defect in steering knuckles
Make: HOLDEN
Model: VT
Variant: Series II
Date Range: 1999
VIN Ranges: 6H8VT@@@@XL477764 - L481630. @ = variable
Status: Closed
Defect: Casting defect in a specific batch of front suspension steering knuckles which compromises knuckle durability.
Consequences: Loss of steering control.
Corrective action: Replace both front suspension steering knuckles.
Notif. Date: 5/11/1999
DOTARS No.: R99/126
Campaign No.: 99-H-06
Problem: Rear semi-trailing arm weld
Make: HOLDEN
Model: VT
Variant: Series II
Date Range: 1999
VIN Ranges: 6H8VTK69HXL486167 6H8VTK69HXL487955 6H8VTK35HXL487159 6H8VTK35HXL487956 6H8VTL69HXL487825 6H8VTK35HXL487967 6H8VTK69HXL487831 6H8VTK35HXL487976 6H8VTK35HXL487840 6H8VTK69HXL488008 6H8VTL35HXL487921 6H8VTK69HXL488020 6H8VTL69HXL487934 6H8VTK69HXL488022 6H8VTK69HXL487938 6H8VTK35HXL488124 6H8VTK69FXL487940 6H8VTL69FXL488130 6H8VTK35HXL488226
Status: Closed
Model - HOLDEN VT Police Vehicle (1997-1998)
Problem: SEAT CUSHION CAUSES SHORT CIRCUIT WITH WIRING
Make: HOLDEN
Model: VT Police Vehicle
Variant:
Date Range: 1997-1998
VIN Ranges: Production Serial Nos L251589 to L296360
Status: Inactive
Defect: Police vehicles are fitted with unique front bucket seat cushions incorporating low side wings. These wings may allow the mat supporting seat cushion to deflect enough to crush wiring routed across the driver's seat lifter motor bracket.
Consequences: Damaged wiring may cause heat damage to seat cushion, and risk of fire.
Corrective action: Inspect existing wiring harness to the seat lifter motor for damage. If undamaged, fit heavy duty PVC tubing. If damaged, replace harness.
Notif. Date: 5/03/1998
DOTARS No.: R98/009
Campaign No.: 98-H-01
Model - HOLDEN VT Series II (1999)
Problem: Steering gear attaching torque not to spec.
Make: HOLDEN
Model: VT Series II
Variant:
Date Range: 1999
VIN Ranges: 6H8VTK35HXL464495 - 6H8VTK69HXL473691 Level 1 & 2 vehicles (excluding Calais)
Status: Inactive
Defect: During assembly of the steering gear, the rackbar and the inner ball joint housing are staked after the specified attaching torque has been achieved. Some steering gear assemblies supplied where the required final attaching torque was not achieved and the subsequent staking has not occurred.
Consequences: Unpredictable steering response causing loss of vehicle control.
Corrective action: Inspect steering gear for a staking mark that validates that correct torque applied during assembly. If stake mark is not positively observed, the steering gear is replaced.
Notif. Date: 12/07/1999
DOTARS No.: R99/094
Campaign No.: 99-H-05
Model - HOLDEN Commodore VT, VX V6 Auto Sedan
Problem: Brass nuts on the LPG supply pipe may crack
Make: HOLDEN
Model: Commodore VT, VX V6 Auto Sedan
Variant: Sedan with LPG
Date Range:
VIN Ranges: 6H8VTK69HWL337246 to 6H8VXL69A2L796980
Status: Active
Defect: Brass nuts on the LPG supply line may crack.
Consequences: LPG may leak increasing the risk of a fire in the presence of an ignition source.
Corrective action: Holden dealers will replace the LPG pipes or arrange repair by authorised agents.
Notif. Date: 22/02/2002
DOTARS No.: R02/003
Campaign No.: 02-H-01
Model - HOLDEN VT, VX, WH
Problem: Low beam headlamp inoperable
Make: HOLDEN
Model: VT, VX, WH
Variant: Commodore, Calais, WH Statesman & Caprice, HSV vehicles
Date Range:
VIN Ranges: L545674 TO L659987 (Plus a small number of vehicles prior to L545674).
Status: Active
Defect: Low beam headlamp relay faulty
Consequences: Low beam may not operate when selected
Corrective action: Holden dealers will replace the low beam headlamp relay
Notif. Date: 30/07/2001
DOTARS No.: R01/065
Campaign No.: 01-H-03
Model - HOLDEN VY
Problem: The drivers seat track may not be securely fitted
Make: Holden
Model: VY
Variant:
Date Range:
VIN Ranges:
Status: Active
Defect: Some driver's seats have been manufactured with incomplete riveting and welding between the seat track and the mounting foot on the front right hand side.
Consequences: The seat may not remain secure in an accident.
Corrective action: Holden dealers will inspect the seat and if required will replace the seat adjuster and guide rail assembly.
Notif. Date: 24/05/2004
DOTARS No.: R04/062
Campaign No.: 04-H-04
Model - HOLDEN VY Adventra
Problem: Front bumper beam needs upgrading
Make: Holden
Model: VY Adventra
Variant:
Date Range:
VIN Ranges:
Status: Active
Defect: The front bumper beam may detach if used with snatch strap in soft sand, mud or snow
Consequences: The front facia may be torn off the vehicle
Corrective action: Holden dealers will fit a stronger beam with a reinforced attachment kit.
Notif. Date: 7/04/2005
DOTARS No.: R05/050
Campaign No.: 05-H-02
Model - HOLDEN VY, VY2, V2, VZ, WK, WL (1 April 2003 to 2 December 2005)
Problem: Side airbag may activate when exiting the vehicle
Make: Holden
Model: VY, VY2, V2, VZ, WK, WL
Variant:
Date Range: 1 April 2003 to 2 December 2005
VIN Ranges:
Status: Active
Defect: Either the passenger or driver side airbag in the seat may discharge when the vehicle is stationary and the occupant is exiting.
Consequences: The occupant may be knocked against the open door.
Corrective action: Holden dealers will fit additional earthing from the seat to the vehicle body.
Notif. Date: 7/04/2006
DOTARS No.: R06/045
Campaign No.: 06-H-02
Model - HOLDEN VY, WK (26 August 2002 - 2 September 2003)
Problem: A power steering hose may rupture on cornering
Make: Holden
Model: VY, WK
Variant:
Date Range: 26 August 2002 - 2 September 2003
VIN Ranges:
Status: Active
Defect: A power steering cooler hose may rupture during cornering
Consequences: Steering will become unexpectedly heavier and in a worst case if oil contacts a hot surface there is a possibility of a fire.
Corrective action: Holden dealers will fit replacement cooler hoses
Notif. Date: 6/05/2004
DOTARS No.: R04/060
Campaign No.: 04-H-03
Model - HOLDEN VZ Commodore, WL Statesman
Problem: LH rear door may not be welded properly
Make: Holden
Model: VZ Commodore, WL Statesman
Variant:
Date Range:
VIN Ranges:
Status: Active
Defect: Small number of left hand rear doors may have been produced with a number of defective spot welds.
Consequences: Defective spot welds may potentially affect occupant protection in the event of a side impact collision.
Corrective action: Holden dealers will replace the LH rear door on the affected vehicles
Notif. Date: 17/12/2004
DOTARS No.: R05/001
Campaign No.: 04-H-09
Model - HOLDEN VZ Commodore, WL Statesman/Caprice
Problem: Tyre beads may have been damaged while mounting
Make: Holden
Model: VZ Commodore, WL Statesman/Caprice
Variant:
Date Range:
VIN Ranges:
Status: Active
Defect: The tyre beads may have been damaged when being fitted to the rim.
Consequences: The damage may cause loss of air pressure.
Corrective action: Holden dealers will replace all tyres on the affected vehicles.
DOTARS No.: R05/002
Campaign No.: 04-H-11
Model - HOLDEN V2 Monaro Srs3 CV8 and HSV Coupe Srs3 (16/7/2003 to 25/9/2003)
Problem: Seat wiring harness may be insecure
Make: HOLDEN
Model: V2 Monaro Srs3 CV8 and HSV Coupe Srs3
Variant:
Date Range: 16/7/2003 to 25/9/2003
VIN Ranges:
Status: Active
Defect: Some driver's seats have been manufactured with the seat memory module wiring harness not positively secured.
Consequences: The wiring harness may be damaged when the seat is adjusted to the lowest position. This may result in the seat moving unexpectedly in a forwards or rearwards direction to the limits of seat adjustment. This may affect the driver's control of the vehicle
Corrective action: Hoden dealers will inspect the vehicles for the presence of a wiring harness retaining clip and will fit a clip if missing.
Notif. Date: 18/12/2003
DOTARS No.: R03/102
Campaign No.: 03-H-04
Model - HOLDEN V2 Monaro Series II CV8 and HSV Coupe Series II (18 December 2002 to 29 May 2003 inclusive.)
Problem: Seat wiring harness - incorrect routing
Make: HOLDEN
Model: V2 Monaro Series II CV8 and HSV Coupe Series II
Variant:
Date Range: 18 December 2002 to 29 May 2003 inclusive.
VIN Ranges: 6G12X14F23L959133 to 6G12X14F83L994307 AND 6G12X14F13L100017 to 6G12X14F33L127459
Status: Active
Defect: Some driver's seats have been manufactured with the seat memory module wiring harness incorrectly routed.
Consequences: The wiring harness may be damaged when the seat is adjusted to the lowest position. This may result in the seat moving unexpectedly in a forwards or rearwards direction to the limits of seat adjustment. This may affect the driver's control of the vehicle.
Corrective action: Holden dealers will relocate and secure the seat wiring harness of affected vehicles.
Notif. Date: 1/07/2003
DOTARS No.: R03/052
Campaign No.: 03-H-01
Make: HOLDEN
Variant:
Date Range: 1986
VIN Ranges:
Status: Inactive
DOTARS No.: R86/014
Make: HOLDEN
Variant: Auto
Date Range: 1986
VIN Ranges:
Status: Inactive
DOTARS No.: R86/015
Make: HOLDEN
Variant:
Status: Inactive
DOTARS No.: R86/016
Make: HOLDEN
Variant:
Date Range: 1987
Status: Inactive
DOTARS No.: R87/017
Make: HOLDEN
Variant:
Status: Inactive
DOTARS No.: R88/032
Make: HOLDEN
Model: VN, VQ
Variant:
VIN Ranges:
Status: Inactive
DOTARS No.: R90/023
Make: HOLDEN
Variant:
Status: Inactive
DOTARS No.: R94/021
Make: HOLDEN
Variant:
Date Range: 1991
VIN Ranges:
Status: Inactive
DOTARS No.: R91/016
Make: HOLDEN
Variant:
VIN Ranges:
Status: Inactive
DOTARS No.: R91/017
Make: HOLDEN
Variant:
Date Range: 1993
Status: Inactive
DOTARS No.: R93/033
Make: HOLDEN
Date Range:
VIN Ranges:
Status: Inactive
DOTARS No.: R95/042
Make: HOLDEN
Model: VR, VS
Status: Inactive
DOTARS No.: R96/083
Make: HOLDEN
Model: VR, VS
Variant:
Status: Inactive
DOTARS No.: R98/063
Make: HOLDEN
Model: VS
Variant: Series II
Date Range: 1997
Status: Closed
DOTARS No.: R97/033
Make: HOLDEN
Model: VS
Date Range: 1997
Status: Closed
DOTARS No.: R97/041
Make: HOLDEN
Model: VT
Variant:
Date Range: 1997
Status: Closed
DOTARS No.: R98/006
Make: HOLDEN
Model: VT
Variant:
Date Range: 1998
Status: Inactive
DOTARS No.: R98/024
Make: HOLDEN
Model: VT
Variant:
Date Range: 1997
Status: Inactive
Consequences: Fire.
DOTARS No.: R99/036
Make: HOLDEN
Model: VT
Variant:
Date Range: 1998
Status: Inactive
DOTARS No.: R99/062
Make: HOLDEN
Model: VT
Variant: Series II
Date Range: 1999
Status: Closed
DOTARS No.: R99/126
Make: HOLDEN
Model: VT
Variant: Series II
Date Range: 1999
Status: Closed
Make: HOLDEN
Variant:
Status: Inactive
DOTARS No.: R98/009
Make: HOLDEN
Model: VT Series II
Variant:
Date Range: 1999
Status: Inactive
DOTARS No.: R99/094
Make: HOLDEN
Date Range:
Status: Active
DOTARS No.: R02/003
Make: HOLDEN
Model: VT, VX, WH
Date Range:
Status: Active
DOTARS No.: R01/065
Model - HOLDEN VY
Make: Holden
Model: VY
Variant:
Date Range:
VIN Ranges:
Status: Active
DOTARS No.: R04/062
Make: Holden
Model: VY Adventra
Variant:
Date Range:
VIN Ranges:
Status: Active
DOTARS No.: R05/050
Make: Holden
Variant:
VIN Ranges:
Status: Active
DOTARS No.: R06/045
Make: Holden
Model: VY, WK
Variant:
VIN Ranges:
Status: Active
DOTARS No.: R04/060
Make: Holden
Variant:
Date Range:
VIN Ranges:
Status: Active
DOTARS No.: R05/001
Make: Holden
Variant:
Date Range:
VIN Ranges:
Status: Active
DOTARS No.: R05/002
Make: HOLDEN
Variant:
VIN Ranges:
Status: Active
DOTARS No.: R03/102
Make: HOLDEN
Variant:
Status: Active
DOTARS No.: R03/052
