reply from whom exactly, the bloody pope!
i have read the whole page, cannot find much there.
yes, temp does have an effect but less than .06 under normal australian conditions.
all that you have shown is that voltage of an LA batt is effected by temp, marginally. which we all knew.....
this does not address the issue that a batt w/ 12.3v will start a car 99/100.
Oh dear, I only provided the link for people to verify hopefully what is generally known, and for the fact that at ~12.3V a battery is only half charged. As you can see(well maybe you cant) even when nearly discharged completely the voltage doesnt really fall below 11.8V, which makes the device that isolates an appliance 11V not really well designed,
WHICH WAS THE MAJOR point under discussion that related to the thread....but some want to try and start brush fires and catch me out on details......not on this issue Im afraid.
Here is a summary of that info directly from the link:
For example, if the electrolyte is at 20° F (-6.7° C), the Open Circuit Voltage reading would be 12.696 for a 100% State-of-Charge. At 100° F (37.8° C), the Open Circuit Voltage reading would be 12.308 for 50% SoC and a reading of 11.773 or lower at 120° F (48.9° C) would indicate a discharged battery.
Most people know that a battery that is on the way out usually first struggles when its cold(how come you dont?), and its not because the open circuit voltage(Im guessing you dont know what that means) drops by 0.06V.... in simple terms, the chemical reaction in the battery doesnt go as well when it is cold.
Go back and look at the
Capacity Load Test which shows battery voltage under load versus temperature, which shows how under load the difference in output is close to 1V with a 40C temp difference, that's with a battery in good condition with 80% charge. 1V difference at the starter can easily make a difference between getting the motor to spin fast enough to start.
It gives some indication of what lies in store with batteries with more travelled batteries at lower levels of charge where the voltage will drop more quickly in a start situation and further.
