red lights in statesman door trim.
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Haydz, Jan 20, 2008.
  1. Haydz
    Haydz Fasten your seatbelts
    Liverpool.Sydney,NSW
    VS UTE LS1 T56
    hey guys
    i just got myself a set of statesman door trims and they have the red light in and im just wondering whether my vr berlina would have the plug for them or. where should i wire them up from. and do you guys reckon it would be ok to use speaker wire?
  2. Harvs82
    Harvs82 Active Member
    Glen Waverley VIC
    MY08 Subaru Liberty GT-B & MY16 VF II SS Redline
    I'd probably just wire it up to the switch that runs the interior lighting, when you open the doors etc. I would probably use wiring a bit thicker than speaker wire though, just to be safe.
  3. shanhsv
    shanhsv Luvo
    Muswellbrook, NSW
    VSII Calais V6 & VSII Senator 215i
    Im fairly sure sure there is a plug in the door for it,is in mine
  4. markovr
    markovr Well-Known Member
    northside brisbane
    07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
    On berlinas and statos the door looms run a extra 2 wires ...one from the interior light 12v+ and the other to the door jam switch which has 2 contacts on it that make to earth when the door is opened not one like the conventional exect door switch
  5. Haydz
    VS UTE LS1 T56
    going to pull it off this arvo and see how i go with wiring them up.
    learnt a fair bit since first posting this
  6. shanhsv
    shanhsv Luvo
    Muswellbrook, NSW
    I swear ive seen the plug for the door lights taped up inside the door.
  7. Haydz
    VS UTE LS1 T56
    i pulled my rear door trim off and i couldnt see it there. might have another look tomorrow. if not ill just hook it up to the interior light loom
  8. Super Coach
    Super Coach GTS, S, CV8Z, SSVR
    HT GTS, VN S PAK, VS S PAK, CV8Z, VF2 SSVR, MSE
    I know this is an old thread but am planning on doing these door lights as well. Can anyone confirm if the lights themelves are the same ones from the glove box? Are they both the same size as I have people telling me I can use the glovebox lights. Would also like to know if anyone is wrecking VS Calais, Statesman as I would be interested in the lights and the surrounds which go with it.
