red motor redline
Discussion in 'VB - VK Holden Commodore (1978 - 1985)' started by c2105026, Mar 21, 2011.
  1. c2105026
    c2105026 Active Member
    NSW
    2000 VTII Commodore Olympic, 2012 Ford Focus ST
    hello all,
    On the 6cyl 3.3 motor fitted to VBs, what is the redline? Max power is at 3800 apparently. Mine is completely stock and in reasonable condition. Automatic transmission seems to naturally change up at 4000-4400 rpm under full acceleration, from what I could calculate. I have seen a wheels roadtest from that period of a torana, where they had it up to 5000rpm, but this was a manual.
    any thoughts?
  2. clutch
    clutch New Member
    Berwick
    VH SL/E, R33 GTST
    the 202's tend to break things at high rpm, and since its such an old car, my advice is not to run it that high.
    just sayin
  3. bogan_vk
    bogan_vk New Member
    australia
    commodore
    i run mine up to 5500rpm all the time and have never broke anything.
  4. VK SL 3800
    VK SL 3800 Well-Known Member
    VK SL 5spd
    5500 is redline, anything above 4500 they tend to scream a little but they have a reasonable solid bottom end so up to 5500 they can handle but they dont like it particularly. The 186 was always regarded as the best of the red motors, generally much smoother and not pushing towards the limits of the block like 202s do.
  5. c2105026
    NSW
    ok, thanks for that - yeh at about 4500rpm the fanbelt starts to squeal, but its a classic cuiser, I try not to thrash it.
