Refreshing Faded Trim
Discussion in 'Spray Painting and Panel Beating' started by b_lake1, Nov 13, 2013.
  1. b_lake1
    b_lake1 Salt Dog
    Aotearoa
    5.7L VY Calais
    As the title suggests team, looking for the best way to refreshing faded black plastic trim. I heard of a trim dye that you rub in, but thought their maybe a better way. I wonder if dying then clear coating would be a permanent fix?
  2. TinSnips
    Hills District, Sydney
    VF SSV Ute
    Some of the trim coatings (not dressings) are very good at this and are a very good semi-permanent option. Do you have pics or which trim exactly are you talking about? The textured exterior plastic?
  3. b_lake1
    b_lake1 Salt Dog
    Aotearoa
    5.7L VY Calais
    Yip the textured black plastic exterior trim. Mainly the plastic within the boot garnish and the cowl vent panel.
  4. TinSnips
    VF SSV Ute
    GTechniq C1 will work well, or CQuartz DLux.
    DLux is significantly cheaper but may not last quite as long. It's probably the one I'd go for on that plastic though.
    CarPro CQuartz DLUX Kit | Waxit Car Care
  5. TinSnips
    VF SSV Ute
    Actually, C1 is pro-only. I think C4 is the consumer version.
    MSDS Sheets
  6. b_lake1
    b_lake1 Salt Dog
    Aotearoa
    5.7L VY Calais
    Cheers chap. Will definitely give that a go.
  7. TinSnips
    VF SSV Ute
    No worries. Key is to give it a good clean first. APC followed by 10% IPA is a good combo. Needs to be super clean to work best.
  8. ari666
  9. hi_ryder
    hi_ryder Donating Member
    Pascoe Vale South, MEL
    till you need to do paint work and the whole car is contaminated with fish eyes...
  10. ari666
  11. wot recession
    wot recession call me wotman
    Gold Coast
    VF SV6 auto Ute.
    A heat gun will bring the oils back to the surface of the plastic trim.
    It only works on the dark grey or black trim. (Non painted).
  12. TinSnips
    VF SSV Ute
    you can 'bake' oil into trim the same way, at a pinch
  13. lemusa
    lemusa Unmotivated Enthusiast
    Christchurch, NZ
    +1 for heat gun. Mate did it on his Golf and it came up looking new. I am yet to try it on the Bimmer, need to enlarge my balls
  14. hi_ryder
    keep the heat gun moving, temp test with your finger. if you have a laser thermometer you probably don't want to go over 80 degrees....
  15. mpower
    mpower Well-Known Member
    I'd love to see a youtube vid of someone doing this, a heat gun - who'd have thunk it?
  16. Demonica
    Demonica Mrs Wraith
    SE Qld
    VS clubsport
    Do it so I can copy you if it works.........or laugh at you when you fail hehe
    Sent from my HTC One
  17. TinSnips
    VF SSV Ute
    There's a bunch of videos on how to do it (and how not to). Keep in mind, it won't work for every situation. And it will fade again if not treated properly.
  18. wot recession
    Gold Coast
    VF SV6 auto Ute.
  19. VS-S
    For black trim, I use black shoe polisher. Does an excellent job at keeping it black and being oil based makes it not wash away when wet. (Washing the car, rained on, etc.)
