Relays under dash look weird - are they unusual?
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Circlotron, Mar 22, 2012.
  1. Circlotron
    Circlotron New Member
    VP Exec 5L BT1 ex cop, ex taxi
    Had a quick look inside the hinged compartment above the pedals / below the steering column and there are four relays there. Thinking about replacing the ignition relay re tracking down an intermittent problem. The thing is, these relays all look like they have a right-angle base or maybe a right-angle adapter. Haven't pulled one out yet, gotta go to work. What's the story here? Are they just normal "straight" relays like the ones under the bonnet, or different (read expensive) ones?
  2. hi_ryder
    hi_ryder Donating Member
    Pascoe Vale South, MEL
    pics?.....
  3. wamboin23
    wamboin23 Donating Member w/ Boost
    Wamboin, NSW
    VS Calais - Cooled L67 + T56 | VR Acclaim V6
    they are just normal relays. should be anyway. bosch part number should be 0332019457
  4. stockies
    stockies Bannana
    S/E Suburbs
    G6E Turbo
    To confirm, the relays are normal, same as what's under the bonnet. The relay mounts are on the right angle to allow for easy removal if they are faulty.
  5. Circlotron
    Cool. Thanks guys.
