VT-565
Hi All,
I've got a 1997 VT Exec V6 with the Getrag 5 speed, just replaced the clutch release bearing this morning after a suspect howling noise made its way in, whenever i pushed in the clutch and dissapeared when i took my foot off. replaced easy as, started her up and there it still is, that damned noise...i have a bit of an idea that it might be the release bearing guide as it's called, which sits on the g'box input shaft, this might be worn enough to let the bearing spin on the sleeve and cause the noise. however, i had a look at that(a quick one, the box was about to jump off the jack) and it looked ok to me.
Anyone with other ideas or run into the same problem?
