rambunctious
- Jun 9, 2011
- 2,553
- 2,868
- 113
- Location
- Alexandra Headland Qld
- VZ Executive Wagon
This applies to my VZ but would also apply to others, and has been discussed before and is actually 2 problems.
One is the car starting then immediately stopping so have to remove the key, then restart the car.
The other is the remote battery needing to be replaced.
I used to have the start then stop problem and I have always believed it had something to do with the remote not having enough charge in the small 2032 battery.
January last year I fitted a new starter and seemed to stop the start stop problem.
Then this January I fitted new car battery which did not change things, then 2 weeks ago the car did the start then stop trick again but this time I simply changed to my other remote which I know had a good battery in it and since then no problems.
So I am leaning toward the remote battery definitely having something to do with the start then stop problem some of us experience from time to time in our commodores.
These batteries are all of about $5 and are easy to replace by simply undoing the 2 screws holding the key then opening the case with a large screwdriver, then use a small screw driver to break the tabs off the small battery, then bend the tabs down so it holds the new 2032 battery and close the case using 3 or 4 small spots of super glue.
Then refit the key and screws.
I've done this about 4 times now so it's easy and I have never used the batteries with the tabs attached as others have.
Now yet another question that comes to mind is that I have read on here that the battery in the remote is recharged by the pin in the remote touching the ring on the ignition, but I am having trouble believing this one as the batteries I am using, 2032, are not the rechargable type and I would think why would these batteries then not catch fire because I know one should not recharge a standard 2032 battery.
Just my 2 cents worth.
