Remote Control Door Lock Receiver
Angela83
40
Greenfields
Ve commodore s2
Hi all can someone tell me where this is located please can someone tell me where this is located in ve sedan
Remote Control Door Lock Receiver​
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Check under the rear parcel shelf in the boot.
krusing
Melbourne, Bayside
Yep,
as @lmoengnr mentioned.
Under the parcel shelf, --> Centre of the passenger's side,
By replacing that unit (RFA), you will need to get all of your Keys Programmed into that Unit.
Takes approx. 10min
Not sure where Greenfields is,
If it was on my daily travels, I would program them in for you.
As I have done a few,
Not sure why they fail.
Angela83
40
Greenfields
Ve commodore s2
Yep,
Takes approx. 10min
If it was on my daily travels, I would program them for you.
Not sure why the fail.
The buttons on my keys were not working. It went to Holden and they said that that unit was no longer working so I got the new unit. I just need to get it put in and get the keys programmed to it.
krusing
Melbourne, Bayside
Are they the original Keys ?
Or
replacement Keys or Key Shells ?
krusing
Melbourne, Bayside
Back seat out,
Then back section of the rear seat out,
You should be able to lift up the parcel shelf, (not to high so it won’t crack/split it), and unclip the RFA, [Remembering the position of it]
pull the old RFA forward to unplug the loom from the old unit,
Plug the replacement unit it,
And clip it back into place,
Refit the rear seat.
Get the Keys/Remotes programmed in.
krusing
Melbourne, Bayside
Southern East Suburbs, Melbourne Victoria.
