remote mirrors
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Panama, Dec 21, 2007.
  1. Panama
    Panama Member
    '87 VL Calais with L67
    since i put my car in at a local holden dealership, the remote mirrors on my car dont work.
    theres no power at the switch, but power at the fuse.
    is there a relay, or a block connecter that might be shagged/ disconnected?
    if so can anyone post a picture or describe it and where it is so i can check please?
  2. TheForgotten
    TheForgotten only human......
    quarantine
    VR EXEC
    could easily be the switch itself. i'm on my third in 3 years. not sure if there's a relay, but i'd assume there is. it'll be in the fusebox under the steering column
  3. dufus
    dufus Donating Member
    rickshaw
    Like TheForgotten said, it could be the switch, I know mine will work one day and stop the next. I really need to get around to replacing it.
  4. kopper69
    kopper69 New Member
    VRII Acclaim
    Have also seen a faulty switch in a mates car, might be worth a try first. Takes about 5 seconds to get it out, no special tools required. If that doesnt work let us know and we can go through the wiring diagrams.
    Having a quick look now power comes straight from fuse 11 to the switch. Ground comes through the LHF Door lock switch. Theres not much else in the circuit. I have heard about a broken wire in the mirror loom before, but the switch is your best bet.
  5. Panama
    Panama Member
    nah im sure its not the switch, because i disconnected the block connector on the grab rail and checked for power on the car side of the terminals ans none of the terminals had power at them. this means that somewhere between the block connector and the fuse there is a failed component or broken wire
  6. kopper69
    kopper69 New Member
    VRII Acclaim
    Fair enough. If Im not mistaken power is only applied to the mirrors when the car is at least on acc? Not sure but worth checking anyway. Check that the switch has a ground and if there is no power there, there has to be an open circuit in the wiring between the fuse and the switch. You can confirm that this is your problem by putting 12V on the switch and it should work again. If that is the case you can either trace the wiring for the break or simply run a new power wire from that fuse.
  7. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    I had my wiring break where it goes through the door.
