Remote not unlocking doors!Locked out.Please Help!
HUMBLZ
VZ
Well today i went for a drive then came home locked the car in the garage then went to go out about an hour later,went to unlock my car and nothing?keept trying and still nothing?tryed the old coat hanger trick but car is deadlocked!
Any suggestions would be great or if other people have had the same problem.I only have the one key but have never had any problems with it in the past.
Thanks!
Rusty
٩(-̮̮̃•̃)۶
Queensland
Vt with VU/VZ bits
Did you physically put the key in the door lock and try and open it??
Rusty
٩(-̮̮̃•̃)۶
Queensland
Vt with VU/VZ bits
Is your car battery flat? I think that could affect the central locking
HUMBLZ
VZ
No battery is fine only replaced 6 months ago with a sealed battery,the dash security lights are still flashing.
Might try get my hand up through the engine bay and disconnect the battery for a while?
HUMBLZ
VZ
No unfortunately any other suggestions might just have to go get a new key cut and programed?
ashbox
back in black
The Car
something black
use the key turn it to unlock with a bit of force and you should feel and hear a slight click
the door will be unlocked but the button will not pop up
HUMBLZ
VZ
Just tryed about 10 times and no go,i hear a click from the back actuator if i turn the key to the left however but that is locking?.
ashbox
back in black
The Car
something black
can't remember, do you have the owners manual, thats where i found it when i had the same issue.
try it the other way, just remember THE BUTTON WONT POP UP
