remote wire problem
Discussion in 'Car Audio' started by [NatHAn], Jul 2, 2008.
  1. [NatHAn]
    [NatHAn] New Member
    Im installing a 10" JL Audio Sub running off a 4 channel kicker amp. The headeck is a Blaupunkt London mp37. Everythings installed and works fine, its just that the amp doesn't turn off when the car does, therefore draining the battery. The remote wire's connected properly, so I don't know what the problem is.
    Any help?
    Thanks
  2. bezz
    bezz Member
    VK
    checked head unit wiring to battery?
  3. [NatHAn]
    [NatHAn] New Member
    What am I supposed to check, ie what could be the problem with the wiring to the battery? as i said the headeck works fine, just that the amp doesn't turn off when the car does.
    sorry for the dumb questions just never had this problem before.
    thanks again
  4. r_i_d_a_h
    r_i_d_a_h New Member
    '97 VS Commodore + '98 E36
    ..possibilty that the remote wire from the head unit may be buggered
    had a similar problem with a previous head unit, except the head unit would not turn on the amps
    try tapping the ampflier's remote wire to the switch/ignition (should be yellow i think) wire of your head unit and see how you go
    thats the solution i used for the previous head unit.
  5. [NatHAn]
    [NatHAn] New Member
    Well the block with the RCA/remote wire outs from the headeck is brand new so i don't think theres anything wrong with the headeck's remote wire. anyway ill try tapping it to the ignition wire and see what happens.
    thanks
  6. bezz
    bezz Member
    VK
    was thinking that you might have the constant connected to the +12v, causing the head unit to stay on and hence the amp?
  7. Tasmaniak
    S.E. Melbourne
    If you disconnect the trigger wire from the amplifier, does the amp still stay on? If so, your amp is cooked!
