Anyone know if it is possible to re-insert the bag which covers the auto shifter without removing the entire centre console... mine is pulling up at the edges and i want to stuff it back down.
yes it is possible. just pull the shift surround out and then you will need to pull the plate that holds the boot in place, put the boot into the right spot the put it all back together. i did the one in my crewy sometime last year.
use this link http://forums.justcommodores.com.au...0145-how-remove-dash-center-console-vy-vz.htm it is in your other thread http://forums.justcommodores.com.au...-2004/75671-how-remove-vy-centre-console.html have a look at the underside of the surround and you will see how it goes together
