remove power window switches
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by luckylou26, Dec 31, 2007.
  1. luckylou26
    luckylou26 New Member
    vr berlina
    I am trying to remove my centre console. I am unable to pull apart the power window switches. I levered them out of the case a little way, but then they seem to be stuck. When I pushed them together again the switches wont click. What have I done?
  2. stocky
    stocky New Member
    you were able to pull apart the switches? howd you do this, cause mine do the same thing and id like to fix them
  3. kopper69
    kopper69 New Member
    VRII Acclaim
    The switches have clips that keep them in. The metal clip is a little fragile though and has probably broken as you tried to remove it. Easiest fix is probably just to put a little glue under it and push it back down. Are you saying the window switches themselves are no longer working? If so they may have come apart slightly when you were removing them causing the metal contacts inside to come out of place. Fix to this is to remove the switch entirely and reassemble it.
  4. PRH
    PRH New Member
    Mildura Victoria
    vp s utility,and a KENWORTH
    The switch should come out far enough to unplug it from the main lume, it has a plug on it with about 200 mm of lead.if the switch itself come apart i doubt you will be lucky enough to get it back together and work again.If its the right hand window switch you will most likely lose the lot coz of the child lock switch on the windows being open circuit.
    When i fitted the power windows to my ute i used a VX ute switch in coz it was 57 bucks for the double switch and to top it off i put relays in there as well.
    Regards Phillip :wax:
  5. luckylou26
    vr berlina
    Thanks for your suggestions. It's beyond my skills. I'm off to the auto electrician
