notthekingswood
- Jun 24, 2005
- 233
- 0
- 16
- Age
- 44
- Location
- Wollongong
- VH SL Wagon
after many year and many problems with my AWD adventra i'm considering dumping the AWD but keeping the ride height as is
I have spend thousands on replacing bushes, drive shafts and now the auto is on the way out and i still have vibrations from the front somewhere plus i've broken afew front driveshafts driving to hard.
i'm hoping its as easy as buying a reco RWD 4L60E and a tailshaft from a wagon (replace donuts, cv and centre bearing before it goes in) then get a tune to remove the traction control (cross track)
I was going to use my old front shaft outers for the front hubs and remove the rest of the AWD but keep it incase i change my mind down the track.
only real issue is the cross track system and how to disable it,, is it possible??
why i want to get rid of it:
- it doesn't really work, if i lift 1 wheel off the ground it spins, the cross track doesn't do anything
- i don't go off road ever
- i like skids as i'm immature
- i want to change the diff ratio to 4.1 and i can't with AWD as 3.46 is the only ratio available for the front diff
- only bought the adventra as a VY SS wagon was about $15k and a top spec VZ LX8 adventra was $7k
- I have no plans on selling the car ever i want to run it till it dies, so not worried about resale at all
- and removing the transfer case, prop shaft, front diff and drive shafts will remove about 150-200kg and driving less wheels might help its economy as its only used around town and on freeway trips, it gets about 12-17l on average depending on use.
