Removing carpet
jayvt
1999 vt exec series 2
does any one have anything on how to remove the carpet in my vt exec.
it is absolutely stuffed and i wanna buy new carpet.
chop out please :)
EDGE3
NEWCASTLE
1997 VS COMMODORE,1996 GTS-R COMMODORE
You can just cut it up bit by bit ,but when you put new carpet in then the seats,floor skirts and console need to be taken out
brinz96VS
Melb
VS II Calais
whats the use in cutting it?
remove front seats and rear bottom seat, center console, kick panels and scuff panel plastics/ trim, lower seat belt bolts and anything else that gets in the way.
EDGE3
NEWCASTLE
Sorry I meant just cut each section I dont know how your carpet fits in your car but mine is just a 1 piece mould,which means that every thing in the way has to be removed so it can go in eg-seats,console,panels.
jayvt
true. i just wanna know if n e one has done it before and if so did they have any problems or anything i should know
EDGE3
NEWCASTLE
As long as you get the correct carpet mould for your car you should not have any problems putting it in,like I said you just have to remove the front seats,console and any panels that are in the way,Im not sure but there might be a couple of places where you need to bolt the carpet in.And the rear seat will need to be lifted up as well.Then its just a matter of putting the carpet in then clipping all the panels back in pressing the carpet down firmly,put the seats back in and your done.
jayvt
mad ****. cheers bro.
