removing cluster
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by VRSTATO, May 9, 2005.
  1. VRSTATO
    VRSTATO Guest
    Just wondering on how to remove the plastic that covers the speedo and that on the dash cluster without breaking or cracking the plastic
  2. Fekason
    Fekason Fekason
    Penrith NSW
  3. speedotom
    speedotom Auto Instrument Repairer
    Ballarat
    2003 V2 CV8-R MONARO
    Two screws on facia up near cluster,
    Now...... :hit: you have to pull the facia out slightly, try and get your fingers behind the facia and gently prise it off, be very carefull around the air vents and clock, because you can easily break the lugs off the air vents. There are a series of clips which are attached to the facia they will come out with a little tug.
    When you have the facia forward just undo the headlight switch, with this undone you can lift the facia up and out of the way.
    Don't forget to release the white plug under the cluster near the fuse box, under two more screws on either side of the cluster and gradually pull the cluster out.
    If you need anymore help just ask
    Tom
