Removing different coloured paint layers
dzach23
Bra Bra Potato Potato
VX Lumina Series 1 genesis blue
my project car was originally Light Blue, but has been painted white and is now matte black by previous owner's. I'm wanting to get it back to it's original blue and want to know the best method of getting the black and white paint off
is paint stripper safe to use and be ok to paint over after or is it better to sand it off?
wildss
44
s.e melb
vnss
either paint over the top with whatever color you want or paint strip the whole lot and start from scratch (recommended)
doing it your way is the biggest #### around imaginable (maybe not even possible to pull off i wouldnt know im not silly enough to attempt it)
dzach23
I am planning to paint just don't want to paint over the black or white paint.
dzach23
Will do then, What's the easiest way to get back to bare metal?
acarmody
Donati..Whoa Green
VX Berlina
Sandpaper, sanding block, a couple of cartons, and a crap load of elbow grease.
the_boozer
no more VK
51
Shitsville Morwell
hilux
id do it that way with 120 on the airsander stay on the edge keep the sander allmost flat it ll get it off pretty qiuck , i only paint strip things off the body away from it the clean up of paint stripper getting it all off the body is too hard.
IMCRZY
YO!
Wollongong
88 VL Excutive Turbo, 00 VT Olympic Edition
Sandpaper?
By the sounds of it the car has had 3 different paint jobs, paint plus primer would add up to about 20 to 30 coats of paint.......
Paint stripper is the only way to go, do u know if the car has had any damage repaired with bog cos if so that is where it will get tricky
