Removing Fly by Wire throttle body on LS2 for twin 4150 cable throttle bodies
Nathant_13
34
Vx HSV Coupe
I have an LS2 going in a hotrod, the standard manifold is coming off for a hi rise with twin throttle bodies on top which are cable driven. Question is regarding the wiring loom as iv been told the ls2 computer needs the fly by wire throttle body to operate?
Ill be getting my harness alterd to be stand alone for the engine only. iv been told I will need an LS1 harness tho.
Any help is much appreciated
_R_J_K_
Zenki S14
So are you running an aftermarket ECU or the factory one?
Probably worth asking your tuner about as there may be a way to turn of fly by wire in the factory ECU, or they can confirm it won't be an issue.
Nathant_13
34
Vx HSV Coupe
Iwas going to run the factory ECU.
Yeah might make a few calls, was hoping someone was doing it on here that could shed some light
