I have to remove the fuel sender on my wife's VR commodore and thought I would ask if there are any special tricks or precautions I should take.
I've located the fuel sender plate on the front of the fuel tank just behind the diff.
Is it just a case of undoing the 5 little bolts and withdrawing the sender unit or does the plate have to rotate as well?
Are the senders usually buggered or do they just need a clean?
How much do they cost (new) or (wreckers) and is it advisable to get new on this particular part?
Will the fuel pump be attached and does it need any special precautions?
I've done some diagnostics and think the fuel sender is the problem because:
1. The gauge only goes up about a mm from empty even though the tank is full.
2. When I remove the sensor wire from the sender unit and earth it, the gauge moves slowly up above half full.
3. When I check the earth wire from the sender unit with a meter, I have a good solid earth.
Any help greatly appreciated so my wife can be happy again. (Happy Wife, Happy Life)
Thanks
John
Thanks
John
