Hi Just wondering how to remove the glove box. my vt had a plastic pin that you pulled out. with my VY there is no plastic pin.
When you open the glove box look up the top on each of the sides near the front and you will see two (one on each side) rubber tangs, which stop the glove box falling down any further, pull these in towards each other and then the glove box will drop down even more, then you just pull the glove box out towards you as it is just clipped in at the back, should take you about a minute flat.
Is there any way to fix them so they don't hang down a little on the passengers side when closed. That gap looks cheap and nasty. or are they all badly moulded ?
its just those rubber stoppers have perished and broken, might be able to find them on ebay or some sort of mcguyver replacement around the house.
