Removing Ignition Barrell
werlegiggy
vs series II equipe
I have recently found that the key won't turn when you try to start the car. From the other postings it seems that you need to have the key in the 'on' position to remove the barrell. Can anybody shed some light on how to remove if I can't turn the key. I have tried using WD-40 to lubricate and still no luck. Thanks for your help in advance.
werlegiggy
vs series II equipe
All good...found the sheer screw and used a chisel to remove bracket from column. Cheers anyway.
