Hi Folks - this is my first post. Can someone please walk me through the removal the left hand mirror on a VT. Thanks in advance. strat
VT External Mirror Hi I need to replace the whole assembly - the head was broken off in a collision with a kangaroo. The base is broken and the mirror head was left dangling by the wiring. I am sure that I could work it out but I don't want to do anything unnecessary. Thanks Bazza
Here you go bazza... *Disconnect the negative cable from the battery. * Remove door trim *Carefully prise off the mirror trim cover and pull the demister duct up out of the door *Remove the mirror assembly retaining (three screws), pull the mirror out and unplug the wiring connector *refitting is the reverse of removal.
As I said last time this came up, I think you have to remove the door trim to access the bottom 2 screws that hold the mirror on. That's what the manual says, but it may not be necessary. Edit: I just had a quick look and you will have to remove the door trim.
