Removing Magazine Holders in VT/VX
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by SIXAPPEAL, Jan 4, 2006.
  1. SIXAPPEAL
    SIXAPPEAL Purple Monkey Dishwasher
    HBD Kitted VX on 20's
    Hi.. The magazine holders in my car have lost their elastic.. I've gone and bought new ones. Can anyone please help me with removing the old magazine holders?
    Thanx in advance. Michelle
  2. evil_monkey
    evil_monkey New Member
    Australia
    Holden
    what you need to do is pull the whole seat backing off theres two clips that hold it in they will break when you pull it off but you should have replacement ones in with the new map pocket basiclly grab onto the rear seat panel at the bottom and pull hard and up youll hear a crack which is normal thats just the one way clip snapping off and then it should just come compleatly off and the map pocket itself is just screwed on and has two one way metal clips to hold it firmly into place
    ooooh and not to mention if your pulling the drivers side one off you need to take the lumbar support knob off which is held on the same way with the same clip you will find in your window winder
  3. dunno vx
    dunno vx New Member
    vx executive s1
    hey 6 appeal how much did the pockets cost iv got one that is stuffed 2
    cheers
  4. SIXAPPEAL
    I paid $37 each. I've heard a few different prices, but I wouldn't expect to pay over $40
  5. SUPERV6
    SUPERV6 SUPERV6 13.299@101.44
    Moonta (SA)
    VT 'S' Supercharged V6
    You can save the clips (instead of sacrificing them) that evil monkey mentioned if you slip a fine screw driver into them in the correct place and angle and release the tab...BUT its very awkward to get yourself under there to see where you're aiming...SO most people just let them snap and replace them. And yes the lumbar knob has a big circlip holding it on ;)
    Reminds me I also have a broken pocket that I've been meaning to change.
    evil_monkey likes this.
  6. EXCESSV
    EXCESSV New Member
    Perth, WA
    VE SSV
    i think every commodore owner from vt onwards has at least one pocket broken and the good old 'i have been meaning to get it fixed.'
    first night i got mine a couple of my mates in the back seat put a few 600ml bottles of coke in there and busted the top clip. that was 3 years ago.lol
    maybe one day i will get it done.
  7. ciaranvt
    ciaranvt New Member
    VT Commodore Exec.
    Does the new pocket set also come with the plastic retaining straps that sit in the inside of the vinyl?
    i think one of mine has broken..
  8. gruzza
    gruzza Guest
    yes every thing you need is in the new pack. Don't worry about the clips breaking there is a new st with each pack. It took me no more than 15 mins to do, the seat knob was probably the only hassle.
  9. ciaranvt
    ciaranvt New Member
    VT Commodore Exec.
    yeah circlips....
    how do you find best to remove em?
    is there an effective tool to remove it?
  10. SUPERV6
    Moonta (SA)
    A flat blade screwdriver CAREFULLY inserted down the side of the knob to find the edge of the circlip is one way and push the circlip off. You may need to reinsert the screwdriver from both sides to get the circlip to evenly move off. To reattach the knob...pre load the circlip back onto the knob then line the knob up with the shaft and press the whole assembly back on firmly until the circlip pops back into its groove.
    And HERE is another thread about the same problem ;)
  11. Hubba
    Hubba New Member
    VT Berlina
    Can you buy just the clips? Mine is fine, just one clip is broken. I haven;t seen them anywhere myself.
  12. evil_monkey
    Australia
    Holden
    when i got my replacement from holden i had to buy a whole new rear $250ish and the bastard dosent line up properly so its almost impossible to clip in my lumbar knob again :( i just had it on without the clip dosent fall off or anything
  13. SUPERV6
    Moonta (SA)
    Finally got around to replacing that broken map pocket.
    Here are the contents of the kit in case anyone may find it helpful later;)
  14. Ballport1998vt
    Ballport1998vt New Member
    wallan
    1998 vt Exec S1 3.8ecotec
    the clip is easy to take off and put back on. You have to use a flat head screw driver and insert it between the seat and the back part of the seat and find the end of the clip and jam the screw driver betwen it and turn the lumbar until it pings off. To put it back on just put the clip back on the turner and push firmly back on.
  15. antvt
    antvt New Member
    Supercharged V6 VT S
    does anyone know if you can still buy the whole part the pocket attaches to? its like the vinyl seat backing.
  16. Christina
    Christina Banned
    Almost genuine VT "S" + VZ "SS" Red Ute + Vk V8
    i tried for like an hour.
    pulling the bottom upward, heard a few snaps, nothing else.
    i can't do it, it hurts my hands.
    there's also two metal clips on either side of the top of the backing, if i bust them am i screwed?
    sad attempt to do something to my car.
  17. Christina
    Christina Banned
    they are on and secure, and looking good.
    brother got them off, i screwed a screw in :)
    friggen car.... it's a dangerous job on your on..
  18. sv9946
    sv9946 New Member
    VE ss ute hopefully, or ss-v
    congratulations michelle i see you car, sixappeal on the current street commodores dvd which comes with the current magazine. looks good as, congrats on a clean mint car which is now on a dvd. :driving:
    cheers michelle from scv6calais
    (matt) :w00t:
  19. Hubba
    Hubba New Member
    VT Berlina
    Where did you pick up the magazine holders from? My clips are broken and they are just dangling off the seats of my VT. Mine are broken and holden wants $160 each to fix them.
  20. minux
    minux Infidel Bear
    buy the clips from holden, about $5. New pocket and clips is $46.
