Removing Mud Flaps Ve Omega
Discussion in 'VE Holden Commodore (2006 - 2013)' started by VaNdLe, Nov 8, 2012.
  1. VaNdLe
    VaNdLe New Member
    VT S1 V6
    Cannot find any helpful threads explaining how to remove them, Ive been using a small screw driver and the rear plugs wont even come out. I really dont understand why or what im doing wrong :s im going crazy atm,. F!@$!@$!@412ing
  2. Aussie Willy
    Aussie Willy Coal Miner
    Hunter Valley
    VE SSV Redline 2012
    Back up a curb with complete disregard, they allways come off, easy.
  3. salute the ute
    salute the ute DRIVING IS A PASSION
    Rowville
    VE Ute Series II Perfect Blue
  4. Aussie Willy
    Hunter Valley
    VE SSV Redline 2012
    ok you nead these, plus some spare plastic skrivets for when you ruin tho ones you remove.
  5. Alex05
    Alex05 Member
    Ve sv6
    If you look at the plug closely there are 2 parts. Outside ring and a centre bit. Between the 2 there are a couple of slots. Use your flat head in a slit and pop the centre part out. Once that's out then you can pull the plug out.
    Jack-vxcommy likes this.
