Hello can someone tell me how hard it is to remove the oil sump from a rb30 its in a gq so clearence isnt a problem, its leaking abit and would like to re seal it.
not that hard a job but is stuck on rather well using three bond trick is to separate the sump and block , use a flexible scrapper and a hammer to slice between the sump and block carefully little bit at a time , easy enough to bend the sump if the sealant isnt cut thru first .
Kent Moore made a SST for holden . http://www.etoolcart.com/kent-moore-pan-seal-cutter-j-37228.aspx
