removing passenger door trim ?
Discussion in 'VY Holden Commodore (2002 - 2004)' started by chescold, Sep 18, 2006.
  1. chescold
    chescold Guest
    I'm 99% into removing my vy door trim and have come to a halt at the lock button .how do i remove this button to remove the trim? as that is all thats stopping me
    cheers Grant
  2. Cobra30
    Cobra30 Member
    VY V6 S2 Crewman
    The red section in the lock button clamps the locking knob to the lock rod in the door.
    Using a small flat blade screwdriver inserted under the bottom edge of the red tab, lever it out about 2 or 3mm, then the lock button will lift off.
  3. davey g-force
    davey g-force I'm a sceptic...
    "...the winner is..."
    02 RX7 S8 Spirit R 13B TT & 2013 Audi A3 1.8T DSG7
    Yep, what Cobra said.
    Good luck with not damaging the red tabs and/or the lock knobs though!!
    If you do, you can pick them up from Holden for about $3.50 each for the lock knob & red tab complete.
  4. chescold
    chescold Guest
    thanks for that, it all comes together now
    cheers
