Hi everyone, I'm going about removing the passenger side rear axle in a 1994 Holden VR wagon. Im not sure how to remove the handbrake so I can get to the 4 nuts that are needed to remove the axle. Any help would be greatly appreciated especially if you can post photos! Cheers, Julian
i would suggest investing in a gregorys manual, then you'll have instructions and the correct diagram infront of you while dismantling and reassembling the brake components, don't really want to miss 1 small thing and have the assembly fall apart in the drum....
You don't need to remove the handbrake shoes, just move them slightly so you can get a socket onto the nut through the hole in the axle.
