Removing Steering Wheel, Heellp :(
vy1sv8
ve ssv ute
Hey, i was just wondering if anyone knows how to remove the steering wheels from the VY commodores, as i got an ss one the other day but i had a look and have no idea how to remove the original wheel. Can anyone help me with this? :cry: thanks :)
vy1sv8
ve ssv ute
No worries anymore i figured it all out :) pretty simple actually now i done it
Rocker2k3
VX II S pac M5
isnt it illegal to change the steering wheel if you have airbags?
vy1sv8
ve ssv ute
apparently, but ive researched the how to's pretty heavily on this issue due to the airbag, and its engineered for the same type of car, so i couldnt see any major issues with it, its been done to MAD-LS1, a bolt on 12 sec sv8 in the latest street commodores issue and that was all okay :)
breast69au
40
VY Executive
hey how did you get it off cause i am keen on removing the airbag so i can rewire tha buttons so that i can use them with my stereo
Jeffro74
Wanna bee SS
yeah i wouldnt mind finding out hot to do it,at holden they have a special tool?
D
Driftwagon
Guest
HI Guys,
Pulling off the steering wheel is fairly easy, from memory
1. Disconnect the Battery (and wait a minute) - neutralises the airbag circuit
2. On the back of the steering wheel is 4 clips that hold on the airbag, you'll need a small screwdriver to release them
3. Remove the airbag connector - just pulls off from memory
4. Remove the stereo buttons
5. Undo the centre nut but leave it on a turn and give the wheel a yank, should cone loose, then remove the nut and off she comes, be careful when reinstalling the new wheel as the wiring goes into a clock spring and if you put it in wrong it will break and you'll get an airbag code. It has a green (I think) window to tell you its in the right place.
Note: When removing the airbag be very careful not to have anything in your mouth etc as if it accidently deploys, it will kill you, chances are pretty slim though
vy1sv8
ve ssv ute
These are basically the things i used to get mine off :) its pretty simple once u get the airbag off, ALWAYS remember to DISCONNECT THE BATTERY though :yeah: And the bolt needs a 30mm socket to remove it, before you put the steering wheel all back together first, place the wheel on and go for a slow drive in a quiet street to ensure it is properly aligned then put it back together, this saves alot of heartache
  • STEERINGWHEEL.doc
M
Mr VWhy
Guest
is it easy to put airbag back in, will you have problems with clips
and will you get a airbag warning light come on or anything generally once the airbag has been disconnected
vy1sv8
ve ssv ute
if you dont reconnect the battery while the airbag is out you should be fine :), and the airbag simply clips straight back in like a plug
