Removing VS instrument warning lights.
VG355
Wagga Wagga
304 wagon/vg commodore ute/hz kingswood/vk project
Hey guys i'm new to the forum thing and i'm looking for some advice on removing the ABS and AIRBAG warning lights on my vs caprice instrument cluster. The reason i need to remove them is i have fitted a vs caprice firewall ,dash,trim and wiring loom to my vg ute and im not using the abs or airbags. any advice would be greatly appreciated.
Reaper
Tells it like it is.
RG Z71 Colorado, 120 Prado , VDJ200, Vantage
Just pull the bulb from the back of the cluster.
IBLOWN
45
VS V6 TT/'13 VF Senator/'11 WM CapriceV/Hayabusa
Why not just get them cleared by Holden or somebody with a good scan tool? If you get a problem down the track with your ABS/Airbags, how will you know?
If you must though, pull out the cluster, take the cover off the cluster and pull the bulbs out from behind.
Reaper
I think you'll find the VG didn't have bags/ABS.
VG355
Wagga Wagga
Im not not using the abs or the airbags. i have used a vs caprice loom and just need the warning lights removed. Thanks Reaper ill try pulling the globes out.
VG355
Wagga Wagga
Thanks IBLOWN.
VG355
Wagga Wagga
Thanks REAPER
ephect
Donating Member
VS Acclaim V6
U don't need to remove the cluster
open the fuse cover under the dash, lie on ur back and look up at the cluster, U will be able to see the bulbs and twist to remove the right one.
VG355
Wagga Wagga
Ok cheers ill give it a go :)
