We tend to get a thread on this almost every month. Either head down to your local auto parts store and buy a window winder removal tool or attempt to remove the circlip that holds the back of the handle onto the winder shaft with a screw driver or a rag.
it is between the handle and the spacer, you need to push the trim back to see it. I found a rag works the best, slide it between the handle and spacer and it should catch the clip.
ok ok i bought a winder removal tool. i press down between winder and spacer i feel something happening, now what do i pull handle off. I am not too sure about this dont wanna break anything.
