Repair WM Caprice HID headlight?
skip100
WM Caprice V8 08
One of my headlights was working only intermittently, and the auto electrician replaced the entire headlight. It cost an absolute fortune. (just under a grand). He said the problem was most likely bad connections (between the ballast and the globe, I think), and it was not repairable.
Is there any chance of having it repaired by a specialist? If so, maybe I could sell it and recoup a bit of the cost.
It's too late now, but could I have replaced the headlight with one from a Statesman? Apparently the Statesman uses standard headlights, and this kind of problem doesn't occur.
I'm thinking I should start trying to source a used headlight for when the other one goes. Any recommendations on suppliers/wreckers would be appreciated.
Greg.
Red Centre Bluey
Alice Springs
Caprice WN, Caprice VR
Old thread, but, your electrician is an idiot.
New lamp ($157) and a new Ballast ($135) were the most that were needed, and both can be replaced separately
Both can be had out of China for a lot less too
VT&VX
89
VX Acclaim
Old thread.
But switch it out for LED bulb and LED switching rectifier (not really a ballast).
