Repairing damaged cd
Discussion in 'The LAN Lounge' started by AirStrike, Jul 18, 2009.
  1. AirStrike
    91' VN SS
    Just wondering if there is any way to repair a damaged cd at all? I have tried but it won't read some of the files, and therefore won't burn a copy either.
  2. S.T.K.E
    S.T.K.E Wiggle Wiggle Wiggle
    Brisbane Northside
    2014 D22 Navara Dual Cab 4x4
    You take it to your local video shop. They charge like 5 bucks and they normaly have one of those machines that cleans the scratch's outta cd's/ DVD's. Works for my little bro's Xbox Games
  3. Goon
    Goon Scientific Tuning
    BrisVegas. QLD
    VY CUSTOM.
    is it a music cd or a game??? if its music rip it, dont copy it..
    if its a game try a cd cleaner. "try another burner/ some lasers read better then others"
    if its an old game, id download a torrent to replace it..its all good u did buy the game, your copys just fked.
  4. AirStrike
    91' VN SS
    It's a data cd.
  5. stocky
    stocky New Member
    try cleaning it with metho, or there are methods using toothpaste that can work too
  6. Doctor Bob
    Doctor Bob Grandpa
    Retired
    RG. Colorado & Caravan
    polish it with brasso or a similar very fine cutting compound then try
  7. TrikkBen
    TrikkBen I'm Back :D
    SE, Vic
    BNR32
    My mate always sprays the discs with lynx, he recons the alcohol cleans them.. Seems to always do the job...
  8. Wagon_Wheel
    Wagon_Wheel Drop A Patch....
    Mt Martha, Vic
    You can try the methods listed but ive tried them before and only fix very minor scratches. Pretty sure JB hifi repair discs for you for a few bucks
  9. Ozzie
    Ozzie JCCC Warrnambool
    Warrnambool
    Ozzie'z Supercharged VY Calais
    I use standard car polish on my data dvd's.
    If the scratch is really bad I use cut & polish.
    Fair bit of rubbing but it does the job
    BUT... if its the data side thats scratched then your lookin at a dead disk
  10. Trayner
    I thought toothpaste wrecked the disc?
  11. Maci
    Maci New Member
    Goulburn NSW
    2003 Holden Statesman
    toothpaste is pretty much a fine cutting compound from what i remember being told about this way to fix a disk, so it works like car polish i'd guess?
    so i doubt it would wreck the disk, but just make sure you give it a good clean if you use that method with some metho or my personal favorite a KFC wipe and a tissue ( might give your drive fresh breath otherwise ;)).
    I still think the professional disk cleaners at your local JB or video shop will be your best chance at getting that data off :)
  12. azkwazere
    azkwazere Ahhh Yes, Ahhh Yes....
    .....SE Burbs
    VP 5-SPD / 24-SPD Racer Hybrid
    Depends on where the damage is:
    On the Clear Plastic Backing? - Use a car polish or toothpaste. Apply a thin layer, polish out in cicular motions towards the outer track of the disc. (DO NOT go around in big circles around the disc, head outwards from the center in a swirly motion)
    On the foil(metalic top layer where the writing goes)? - Your stuffed. Any data thats on that track is pretty stuffed, depending on the scratch location, you can recover the data using a data recovery program which will attempt to emulate the missing bits via looking at pre/post bits but its likely to take large blocks out with even a small scratch.
    Although there is no data kept on the perspex bit at all, you cant keep cutting it down with polish. It is designed with a certain level of refraction which will degrade with each clean.. eventually the reader will throw errors.
    aZk.
