Repairing wiper switch
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by levymetal, Oct 7, 2008.
  1. levymetal
    levymetal TURN MY HEADPHONES UP
    Somerville, Victoria
    HSV ENHANCED VP CALAIS
    Got a vp calais with a broken wiper switch. It all works but it pops out. I read somewhere that you can't fix it, but I can't find any more information on it. Has anyone ever fixed it before? It's rare and expensive and required for rwc!
  2. Turd Ferguson
    Turd Ferguson Donating Member
    N.S.W
    Disco
    the actual switch, or the spurting button, or the variable speed controller. theres alot of wiper switched in the calais lol
  3. levymetal
    haha the switch 1, 2, etc, and the spurting button
  4. wrx884
    wrx884 WA's ASR Rep
    VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
    These r not really that rare or expenive u can get any type of switch aslong as its the same colour as urs. but even then u dont need 2 aslong as u use the internal parts.
    Ok take the bottom PCB board off its housing its a small board about (40mm x 20mm), unclip it, the most important thing u have 2 b carful here is not 2 bend the metal tab that touches the metal rod that the switch knob turns on. (wen that touches the metal rod the squirters work.
    Once thats off theres a circlip on the back of that rod, take that off then the metal rod should just slide out with the knob. Now theres a small round platsic bit (almost the size of a 5c piece) that screws onto the other end of the rod, unscrew that then the knob and that plastic bit should just fall out of the prongs thats used 2 keep the knob in place. u may not even need 2 unscrew it the platic round bit can pop out of those prongs on its own, then reverse procedure.
    If that plastic round bit has broken away from its own thread which is usually the case u can use some (i think its metric mayb imperial not sure) thread with a small screw head on it and use that 2 attach the plastic bit so the knob clips back on.
    hope that makes sense sounds better in my head hahaha.
  5. Tibokan
    Tibokan New Member
    VP Wagon
    Is it broken? If it isnt, and has just popped out, you can glue back into place. It popped out in my VN, and I was able to glue it back in with no problems. Make sure you use the super glue designed for plastics (should have 2 parts, a preparing marker, and the glue). Place a line of glue on the outside edge of the switch and just push it into position on the cluster. Wait a couple of minutes and if all goes well, it should work fine. Hope this helps, as yeah the switches are f**king expensive as to get, especially for a calais
  6. levymetal
    thanks for the replies, but i ended up getting one from the wreckers for $50 haha. (calais of course, with the little knob on the variable wiper speed control!)
