Replace brake globes VX Commodore S
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by spudnz, Jan 22, 2009.
  1. spudnz
    spudnz New Member
    VR Calais
    I need to replace a brake globe on my 2001 Commodore S VX. Can someone please tell me how to do this? I can not see an easy way in to it. There are two screws holding one end of the light cluster in but it still will not come off (do I force it some more?). Thank you for any help.
  2. pablo
    pablo Donating member
    Was a 1997 vt v6 wagon
    Are you working from inside the boot or on the outside trying to take off the plastic lens?
  3. lout
    lout Well-Known Member
    Langwarrin Victoria
    VX Executive S2
    undo the 2 screws then slap (with palm of your hand) tail light housing outwards (sideways) do not try and pull backwards
  4. Sabbath'
    Sabbath' Redblock Jesus
    80 Series// MK5 GTi//
    Undo the two screws. The outer side is held in by two plastic prongs. It's meant to be a tight fit to get it out. Just do as said above. Then once out, simply swap the globes over, put the prongs back in first, knock them home and do up the screws.
