Replace engine mounts VR
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by SSbeast, Oct 16, 2006.
  1. SSbeast
    SSbeast New Member
    I want to replace my engine mounts, but don't have an engine hoist, can i use a bottle jack under where the engine bell housing meets the transmission to relief the weight? Also does anyone know the correct jacking points on the VR's? Thanks.
  2. immortality
    Sth Auck, NZ
    i've previously replaced engine mount by putting a jack under the sump with a lump of wood to spread the load. do one side at a time. unfortunatly i've never done it on this model
  3. dmitch
    dmitch DonkeySS
    Perth W.A
    VS SS S2
    have 2 do this 2 my vs ss any1 know where i can get some high performance polyurethane engine mounts
  4. sganro
    sganro i speak before i think
    NQ
    yet another VS
    i did the engine mounts in my VN just with a jack under the sump, so i cant see why you wouldnt be able to do it with yours. good luck:thumbsup:
  5. Slow VR
    Slow VR Another White Crummodore
    Cairns, Nth Qld
    VR Series II
    High performance engine mounts? WTF..... U must have a serious amount of HP under ur bonnet to require them (if they exist)
    Is a bit of a prick of a job, need to remove the A/C compressor on the pass side.......
