Dayvo
Because i can
- Apr 28, 2005
- 2,669
- 8,486
- 113
- Age
- 67
- Location
- South East,Victoria
- VE SV6 Series 2
This is quick " how to " replace those plastic window runners .
You will need a philips head screwdriver , a flat blade screwdriver ( to pry off the old runner ) and a G clamp.
https://forums.justcommodores.com.a...vx-detailed.83696?highlight=door+card+removal follow this link that Ozzie posted to remove the door card .
Next pull back the plastic to gain access to the window arms and runners , you might have to wind the window up or down to gain access to the runners .
Most of the time you will find ,just like mine has done that the arm has come out of the runner , thats the main cause of window rattle . If it is still intact , pry it out with a flat blade screwdriver.
Next , clean out the track and put some grease on the new runner and slide it into the channel .Line up the hole in the runner with the knob on the arm . You might need a second pair of hands to line it up while you pop it into position with the clamp . Tighten the clamp till you feel the arm click into the runner , undo the clamp , wind the window up and down to make sure all is ok , and job is done . Took me about half an hour from start to finish.
