hello,is there step by step instructions on here for changing my tail lights please,so i don't break anything ,thanks for any help
Open Ur boot Undo the two screws on the side for each light Pull the carpet out from behind the light Disconnect the wiring connection Then pull wiring through little plug Then pull the tail light off from the out side The part of the light closest to the back door is hard to get out pull it fairly hard Then do all the same to get it back in It worked for me any way
