Replaced standard fuel tank with long range tank..Now car keeps cutting out
bj42turbo
51
1990 VN Executive
I just installed a 85L tank out of a VS Statesman into my VN v6.....It seems to idle OK, but when i drive it, it cuts out every 10 seconds or so....
Any ideas?
Cheers Dazz
88GreenVN
Next Exit Left
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
It would have to be running out of fuel for some reason. How much fuel did you put back in the tank?
bj42turbo
51
1990 VN Executive
[jonnoo];1822987 said:
hows the fuel pump?
Dunno, thats way to complicated LOL...I just assumed it was OK
Jonno
Vic,
Hmm - yep thats enough hey :)
Is the pump priming every time you turn the ignision on?
as in do u hear it going vrrrrr when u turn the keys to accesories
its a external pump yer?
could be something as simple as the fuel filter got blocked up by crap tht was in the tank before u put it in
bj42turbo
51
1990 VN Executive
Internal pump
Not hearing anything when key at acc, the old / tank pump was very noisy
Dazz
bcw61
Northern suburbs of Adelaide
VZ 2005 Executive Wagon
Any ideas?
Cheers Dazz
IIRC, the VN long range (V8) tank has two pumps, in lieu of the single (internal tank) high pressure pump for the standard tank. The long range tank has a low pressure pump internal to the tank, with a high pressure pump (with an external pulsator) outside the tank.
If you have simply hooked up the standard connection when you replaced the tank, then chances are you are only running the low pressure pump - which sort of relates to the problems you are experiencing.
You may need to add a connection to the external high pressure pump, to ensure it is running, to sort things out.
