replacing 5hdd auto with 6hdd
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by heathy, Jan 17, 2008.
  1. heathy
    heathy New Member
    vs ute 1995 v6
    Currently i have a 1995 vs ute which needs the auto trans replaced, the vin tells me its a 95 but i cant tell what the auto code is , the sticker is missing , can i stll identify it ? I belive it should me a 5hdd ? A friend has a 6hdd tranny that has come out of a vs 95 sedan and the vin number conferms this. my qustion is can you put a 6hdd were a 5hdd was??. because it looks like you can. ??
  2. Boonz
    Boonz Donating Member
    berri, south australia
    green 355 VG ute
    yeh you can, series one and two VS trans are the same and interchangable
  3. Doctor Bob
    Doctor Bob Grandpa
    Retired
    RG. Colorado & Caravan
    the number is pin stamped near the back edge of the pan
  4. matthewfredericks
    matthewfredericks New Member
    townsville
    vr
    I have just replaced a 5HDD with a 6HDD in my son's VR it won't engage in any gear. the only difference i could see was the speedo wiring at the rear of the box so i haven't connected it yet. Could that not being connected stop it from engaging in gear?
  5. Maxmadmat
    Maxmadmat Member
    Rotorua, New Zealand
    VR Berlina Wagon 3.8 & VS Sedan Manual 3.8
  6. Jxfwsf
    Jxfwsf Well-Known Member
    Aus
    commodore
    the vss being unplugged will effect the trans and it won't change gears as it won't know what speed it is doing, should still be able to select 1st and move though (it just won't change to 2nd etc when accelerating)
  7. allan01
    allan01 Member
    Booroobin
    VQ Statesman 185i
    They say ID number Example (6HDD-7HDD) depends on what year it was made rounded off.
    Mine was late 96 model vs and it had a 7HDD being a late 96 model and i able replace it with a 6HDD and it works fine.
    i would say if its a very late 95 year model Ute then it will take a 6HDD, but if its an early early 95 i would say just replace it with another 5HDD, or put the 6HDD in and go to your local wreckers and pull a computer from a VS sedan that has a 6HDD in it, you can check the auto box code by looking down the back of the engine right hand side of the firewall.
