replacing battery on a vx berlina,computer questions
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by warrick, May 10, 2007.
  1. warrick
    warrick Active Member
    brisbane
    VF 6.0 CALAIS V
    hi
    this is for my next door neighbour.he has a vx berlina & when he replaced the battery the other day all his presets,fuel consumption,trip distances etc where all wiped.everything except his odometer of'course.he also said if he sets his trip computer it wipes all his other info.is this normal?i had to disconnect the battery in my vy berlina the other day & didnt need to reset anything or is this only on vy or later models that you can do this?
    cheers
    warrick
  2. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    It depends on the time you have the battery disconnected. Sometimes there is enough residual power left in the system to keep the memory. Maybe there is a memory in the VY ECU, I don't know, but usually disconnecting the battery will reset the ECU and you lose all the trip computer info.
  3. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
  4. jimcraig
    jimcraig New Member
    vt berlina
    where can i get copy of codes for vt v6 berlina to print an check
  5. TheForgotten
    TheForgotten only human......
    quarantine
    VR EXEC
