Like BlackVXGTS said, the ECU can be linked, but generally mechanics don't want to play around with electronics, particularly if they're more into spanner spinning. They'll ask for the complete set because they can just swap it in and not have to delve into the electronics side of using a Tech2/expensive scan tool (or they just don't have one). TBH though, it seems the complete swap doesn't work as smoothly as many times as it does. There are definitely people in Melbourne who can link it for you, you might just have to look for somewhere a little more specialist than the local.
Injectronics should also be able to repair your original, they will have done a fair few:
[/URL]
See this Envyous post:
[/URL]
Suuuper common issue. There used to be a good Injectronics technical bulletin about it but I can't find it now. They were failing in droves from about 2016ish onwards (but I'm sure plenty before then too), basically the reason why I was telling people not to buy V6 VZs as it's just a pain of a problem to deal with (at least VE timing chains are readily available and so so specialist). Even while Holden was actively stocking spares there were constant shortages (even at wreckers) on VZ V6 ECUs with like 6+ month waits because there was an epidemic of them failing. The VZ V6 ECUs ran very hot, so it really wasn't super smart to then attach them to the front of an engine.
