Replacing front k frame vy ute
ant797
bunbury
vy s
Anyone replaced the front k frame on a vy s ute is it hard seen people talk about using a jack instead of a hoist on other models but cant see how i can do that becuase the bottom of the engine seems to be surounded on the frame and the jack will prevent me from removing it
ant797
bunbury
vy s
will a vu ute k frame fit into a vy ute both 6s
vc commodore
Like the Leyland Brothers
VC, VH and VY
K frames are identical.
I have used an engine crane before to hold the engine, whilst changing K-frames..
You can use a jack on the sump, with a block of wood, but it's not something I'd recommend, as you run the risk of damaging the sump
ant797
bunbury
vy s
How do you get the frame out though with a jack right in the of it
vc commodore
VC, VH and VY
Unbolt everything attached to the K-frame (ie control arms, Z-bars and front wheels.)...The brakes and struts can stay in situ) and drop it straight down, then slide it out the side of the car
ant797
bunbury
vy s
Mentioned on the report the sway bar control arms have movement rectify worn or missing bushing should i replace the whole control arms do they wear out or just the bushes
shane_3800
35
places
vr commo
He's asking because the cross member will be trapped by the jack
shane_3800
35
places
vr commo
vc commodore
VC, VH and VY
Not with everything unbolted from the K-frame....How many have you done? Me, lost count after 100+
